주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
가스 및 전기 온수 탱크, 보일러, 가정용 열교환기에 대한 수리 안내서 및 지원 정보입니다.
Ferroli DOMICompact F24B F5 error
I also have the issue of the fan not working and error code F5 as someone else posted a few years back, but in my case, the fan is ok, has continuity and resistance of 47.6 ohms and is free moving.
The issue is, the fan isn’t getting power from the PCB so is the PCB at fault or is there something else I can check? Can anyone help?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Hi,
Don't know the answer but looking at an image of the control board there appears to be relays on the board and there is one directly above where the fan connects to on the X7 plug connector.
You may have to remove the board and then follow the appropriate traces from the X7 connector, pins 1 & 2 and check where they go. If they connect to a relay then check the relay connections on the solder side of the board. If they appear to be electrically OK and not a dry joint you may have to check by tracing the relay's operate path to see if that is OK.
I couldn't find a schematic for the board (is it a mf08fa.1 as shown in the owner/service manual?) which would make it easier, but there are replacement boards available online when searching for Ferroli DOMICompact F24B mf08fa.1 if you decide on replacing the board.
If you spot something amiss on the board or are not quite sure, post some images back here. Here’s how to do this 기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
cav130 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 50
전체 시간: 1,443
