주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
가정용 전기 설비는 전력을 집 안으로 끌어오고 다양한 콘센트, 가전제품, 조명 기구로 배분하는 복잡한 전기 구성 요소 시스템입니다.
Water damaged double socket
I had water leaking into my garage and water has gone inside the socket unit, which was tripping my lights in the house, I shut down the fuse box and the lights in the house came back on, having investigated it I found the socket to be wet damp and I'm drying it out, will the unit work when dried out or will it need replaced. Thank you.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi,
It depends on how wet it got and also what the socket’s electrical connections material is made of as the impurities in the water can create corrosion which may be a problem later on, especially if it is humid where you are.
Check that the electrical cable is also completely dry. I don’t know about electrical cables but have seen the results of water traveling up by capillary action under the insulation covering telephone cables and causing problems so I imagine that electrical cables would be no different.
Usually sockets aren't that expensive to replace so it may be better to replace it if in any doubt. Just my opinion on this
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
guyarbuckle 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 24
전체 시간: 628
