주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Xperia Z5 안드로이드 스마트폰은 2015년 10월에 출시되었습니다. Sony Xperia Z5는 5.2인치 1080 x 1920 픽셀 디스플레이를 특징으로 하며, 퀄컴 스냅드래곤 810 프로세서와 3GB RAM, 23MP 후면 카메라를 탑재하고 있습니다.
screen became almost black
Hi Everyone,
Suddenly, I noticed that the phone’s screen became very dark. I needed to put the phone near by a bulb light to be able to see what is on the screen as this made the phone increase the light of the screen. At the same time the phone was very hot although it was not charging (not connected to a charger). I tried to reset the phone however, I noticed that the phone is heating more so I opened the phones cover and disconnected the phone’s battery. I waited few minutes until the phone cooled down then I connected the battery. at this point something started to burn inside the phone. some smoke came from under the metal plate where the red arrow is pointing to in the uploaded photo.
이미지
이미지
이미지
이미지
이미지
이미지
I believe there is a burn mark on the back of the removed little cover. It can be seen on the second and third images.
Does anyone know what I need to do to repair the phone?
Thanks in advance
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
M Hassan you will have to remove the EMI shield to properly identify which component has failed. As you can see there are many so unless you remove it, we cannot assist you any further.
이미지
Update (10/26/2020)
Still trying to find the eplist for this phone. Typical Sony since they no longer have schematics at all. It may take a while. Part s are identified by reference designator
이미지
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
oldturkey03 - I have added more photos. Could you please check my post (question) again?
Thanks
의
Sorry, What do you mean by eplist?
Also could you please tell me how to find the parts that you mentioned on the photo?
Thanks
의
M Hassan partslist for the circuit board. That way we can determine what values the capacitor and coil are supposed to be. A few years ago Sony stopped using schematic in their service manuals etc. so it is hard to come by via the usual sources. Still working on it but it is not going to be a fast fix :-)
의
댓글 달기
답변을 추가하세요
M Hassan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 3
지난 30일: 14
전체 시간: 465
