주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2010년에 출시된 자동 제상 기능과 결로 방지 히터 스위치를 갖춘 양문형 모델인 GE 냉장고 GSH25JFX****에 대한 수리 및 정보 세부 사항입니다. 이 페이지는 GSH25JFX**** 패턴과 일치하는 모델 번호에 대한 정보를 다룹니다.
water dispenser not working.
My GE side by side refrigerator will not dispense water out the door. When you push the paddle you can hear the switch click but not a drop comes out. The ice dispenser works and the ice maker is working. The water supply is reaching the ice maker and the filter must be good for water flow to reach the ice maker. Ay suggestions?
Update (10/27/2020)
2011 ge side by side model# GSH25JFXBB. thanks, jim
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Hi @buchele ,
What is the model number of the refrigerator?
댓글 달기
답변 1개
선택된 해법
Hi @buchele ,
Check that the water inlet valve, for the water dispenser is working. (see part #800 - Machine Compartment parts diagram for location)
Your model has two water inlet valves, one is for the ice maker and the other one for the water dispenser. When you operate the switch at the dispenser, it signals the control board to operate the valve allowing the water to flow.
The supplier in the link was only selected to show you what the part looks like (note the dual valves) and where it is located.
If the valve is faulty there are other suppliers online that may suit you better. Just search for GSH25JFXBB parts to get results. Alternatively search for WR57X10032 (this is the part number). Here’s another image that shows which valve is for used for the ice maker and which is used for the dispenser i.e. ice and dis
이미지
(click on image to enlarge for better viewing)
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
james buchele 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 299
