주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Envy 15-k 시리즈에는 7가지 서로 다른 모델이 있습니다. HP Envy 라인업은 총 13개의 서로 다른 모델로 구성되어 있습니다. 15-k 시리즈에는 15-k000부터 15-k099까지의 모델이 포함됩니다.
Upgrade storage with an ssd
Can I upgrade the available storage with an ssd?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Hi,
You should be able to but just to make certain, what is the full model number of the laptop?
의
I think it’s k203tx.
의
댓글 달기
답변 1개
선택된 해법
Hi
It looks like your’s is the model that already has a HDD installed and perhaps you can add a SSD, as there is provision for a sata HDD and an M.2 SSD on the motherboard or if you can add the M.2 SSD then you can have 2 x SSD by replacing the HDD with a sata SSD and adding a M.2 SSD as well.
Here’s the maintenance and service guide for the laptop, taken from this webpage.
Go to p.62 to view the necessary pre-requisite steps and then the procedure to remove/replace the HDD.
Go to p.67 to view the necessary pre-requisite steps and then the procedure to remove/replace the M.2 SSD.
Here’s a link to a RAM and SSD supplier. It is only to show you what SSD (sata and M.2) are compatible with the laptop. There are other suppliers that may suit you better. You can also upgrade the ram to a maximum of 16GB (2 x 8GB) as well if you want to.
Hopefully this is of some help
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Prashanth T 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 13
전체 시간: 1,254
