주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fujifilm FinePix S4200은 2012년 Fujifilm에서 출시한 1,400만 화소의 브리지 디지털 카메라입니다.
Solid white lcd screen
My fuji finepix s4300 lcd screen stays white what should I fix?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi @jameslk2131 ,
Try taking a picture and download it to a computer and check if the picture is OK or if there is just a black image or even if you can access the camera OK. I realize that you cannot “see” what you’re taking in the camera’s LCD screen but this is just to test if the problem is with the LCD screen only or with the camera’s motherboard.
If you can take a picture and can download it and it is OK then the problem may be with the LCD screen. Initially as a DIY repair all you can then do is to replace the LCD screen and check if it works OK.
I cannot find a Finepix S4300 LCD screen replacement guide or teardown video, but here’s the ifixit Fujifilm FinePix S4200 LCD 스크린 교체 guide that may help as hopefully the cameras are similar.
I couldn’t find a replacement LCD screen part online for your model, (or even for a S4200), you may have better luck.
What I did find however is this. Everything that I could find indicates that the same LCD screen is used in both cameras, so this can be used as a donor parts camera. Given the cost it may be an option to consider if you also cannot find a screen.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
James 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 57
전체 시간: 1,431
