주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP 10 2101 J6F00UA는 HP의 다양한 10인치 디스플레이 태블릿 중 하나입니다.
The tablet Fails to charge
Sometimes it will charge for a short time, then all of a sudden it stops charging.
Update (11/30/2020)
Different connector cables have been used to eliminate the possibility of a malfunctioning connector cable. Thank you.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi @jojorep ,
It may be a faulty battery (even rechargeable batteries have a lifespan) or perhaps a faulty or loose micro USB charge port.
Use a magnifying glass and a strong light to visually inspect the charge port for any obstructions that may be preventing a good electrical connection. If there is anything in there, do not use a metal pin to try and clear it. Use a vacuum cleaner instead, to try and clear it.
If the charge port appears to be OK, here’s the maintenance and service guide for the tablet.
Opening the tablet will allow you to check if the micro USB charge port is securely connected to the systemboard.
If it appears to be OK then go to p.16 to view the necessary pre-requisite steps and then the procedure to remove / replace the battery.
At the top of p.16 you’ll find the battery spare part number (784326-001). If you search online using the part number only you’ll get results for suppliers, although the few that I checked didn’t show a price for the battery.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Joseph 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 6
전체 시간: 405
