주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ecovacs Deebot 900은 집안 바닥을 진공 청소하는 자율 주행 로봇입니다. 이 페이지에는 수리 안내서와 문제해결 팁이 포함되어 있습니다.
How to replace LDS (laser sensor)?
This seems to be one of the most common problems in this vaccum cleaners. Is there any tutorial on how to repair the LDS malfunction error? And where to find the replacement parts needed?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
error message Dlof laser component malfunction. What does this mean and how can I resolve this issue?
의
댓글 달기
답변 4개
가장 유용한 답변
I didn’t realize it was a belt, I thought it was just an o-ring. I dismantled my R95 trying to find out why the LDS wasn’t rotating anymore and found the rubber o-ring/drive belt broken and slightly jammed into the rotating navigator which houses the lasers. It came out pretty easily. There is a repair place, ifixrobot.com/Ecovac but they never responded to me. It took a while and many trials but a friend has a machinists book of everything and he determined what size o-ring I needed for the drive belt based on the measurements of the broken o-ring and then found it on Amazon. It’s working well. I didn’t take any photos and feel awful for not doing so for others but the video link below does cover what I did although in a less direct manner. I will tackle the project again after I fix my Shark and post photos in sequence. In the meanwhile for the R95 DEEBOT and the LDS 002 navigator (presuming it might be used on other Deebot models), the belt is a 2-042/N7 70 Buna O-ring the size is 3-1/4”x3-3/8”x1/16” With any luck this link will still work when you need it.
https://www.amazon.com/dp/B01D0BD8KO?psc... https://www.amazon.com/dp/B01D0BD8KO?psc...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
jmbaroso take a look at https://www.youtube.com/watch?v=9StRbMPP... |this video) see if that helps. If so make sure that you create a manual for the rest of us https://www.ifixit.com/Guide/new
이 답변이 도움이 되었나요?
점수 0
댓글 달기
One guy on Amazon said he clears this error by removing the pet hair that might be stuck around the sensor on . I tried a similar solution and forecfully blew air all around the sensor. Cleared the error straight away.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The comun problem with this unit when LDS error appear is the belt that move the lazer motor is broken…,
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
What do you use to replace broken belt, and where do you get it Thanks Joe
의
댓글 달기
답변을 추가하세요
jmbarroso 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 45
전체 시간: 15,285
