주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
일본 이외의 모든 시장에서 판매된 3세대 Toyota Camry. 1991년~1996년형 모델은 XV10 시리즈 Camry 차량이라고도 불립니다.
Replacement of stabiliser arm rubbers
How do I replace my stabiliser rubbers at the back.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Can you change bushings on the rear camber arm bar on a 1996 Camry? Or do you have to purchase an entire camber arm bar to get the new bushing?
댓글 달기
답변 1개
가장 유용한 답변
I suggest you remove the tires and jack your vehicle up, or you could do it on a ramp. As long as both rear wheels are lifted the same amount, there will be no load load on the sway bar. Remove the two bolts holding the bracket in place. Remove the bracket, remove the old bushing and install the new bushing. They are split bushings and should be relative easy to remove. Remember that there are two different size stabilizer/sway bars. Make sure you measure yours so that you can get the right size. You will probably also need some WD40 or similar to remove the old bolts. Most of the time they are rusted and a bit of a PITA to remove. Replace those bolts as well, will safe you a lot of headache after. Hope this helps. Good Luck.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
willem 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 1,012
