주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 2월에 출시된 Bose SoundLink III는 Bose의 SoundLink Mobile 스피커 3세대 모델입니다. 현대적이고 미니멀한 디자인의 Bluetooth 지원 휴대용 스피커입니다.
Bose speaker not charging
My bose portable speaker is not starting after its battery reduced last night.
I hv tried changing cables also(Type C) still its not starting.
please suggest
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
I've got a powercolor 2. The battery ran completely out, and now it will not take a charge or turn on (no lights turn on).
If I plug it into the computer, the computer will detect it and "set it up", however, when I try to run the Bose updater, it fails because the speakers won't communicate with the computer.
There is a popular solution if you search for it - keeping the power button pressed while plugging it into a computer and then unplugging it and letting go, then plugging it back in and pressing the power again, but this does not work for me.
I used them recently and they worked for a number of hours without a charge, so I think the battery is fine, and a quick search online shows this is not an uncommon problem for these speakers. Just want to know what to try next.
Thank you in advance!
의
댓글 달기
답변 1개
선택된 해법
hariom gangwar  not quite sure what you mean by this “battery reduced “ but I’ll assume you mean the battery went down and did not longer work. Since you already tried a different cable I suggest that you change the battery. IF nothing else it will provide you with a known-well starting point for further troubleshooting. Let us know which Bose speaker this is so we can try and help you further if needed.
이 답변이 도움이 되었나요?
점수 1
댓글 6개:
It is recently released bose portable speaker bought 1 months back.
Its battery was low last to last night approx 1-2 % and we left it for changing at night.next day onwards its not starting
의
@hariom gangwar since this is only 1 month old, return it and have them fix it under warranty. After all, you paid for that.
의
Mine is out of warranty. It’s not been charged for a couple years due to moving. What do I do?
의
It is a Bose sound link Bluetooth speaker ||| or 3
의
I’ve had it on the charger for over an hour I still have no light coming on. I understand it needs to be charged extensively but if you could tell me how long before I might see a power light emerge?
의
댓글 1개 더보기
댓글 달기
답변을 추가하세요
hariom gangwar 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 7
지난 30일: 31
전체 시간: 3,049
