주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple Inc.에서 제작한 3.3인치 높이의 Siri 지원 스마트 스피커입니다. 2020년 11월 16일 스페이스 그레이와 화이트 색상으로 출시되었습니다. 이후 블루, 오렌지, 옐로우와 같은 새로운 색상이 추가되었습니다. 모델 번호는 A2374입니다.
Splicing a new USB-C cable on HomePod Mini
Does anyone have the pinout color code for the attached USB-C cable? Within an hour of unboxing my HomePod Mini, my parent’s dog chewed the connector off the cable. As the official repair cost to repair is nearly the cost of a new device, I’m going to attempt to splice a new cable onto it. Anyone who has done a teardown or just taken it apart, would you be able to help me out?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개
The official Apple cost for repairing the cable is only 29$.
의
@tassilomoedl 29$ (Groceries for a day) saved if you do it yourself.
의
@oldturkey03 Yes, but the OP said it costs almost as much as a new HomePod, and that‘s not correct.
의
@tassilomoedl you are right, it is not. However, repairing the cable still saves the $29 you mentioned :-)
의
댓글 달기
답변 1개
선택된 해법
Hi @alexdavila ,
USB-C, as with all USB types, are wired to a standard, so the wiring will be the same for each type of USB connection.
The difficulty with USB-C, as opposed to USB 2.0 say, is that there are more wires and that there are wires having the same colours but they are used for different functions and accidentally connecting them incorrectly would cause problems.
You would need to identify the wires at one end of the cable and ensure that the wires were correctly terminated at the other end.
Here’s an image showing the pinout for a USB-C socket and plug which may help.
Here’s a link to the ifixit HomePod Mini 분해 guide as well
이미지
(click on image to enlarge for better viewing)
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Alex Davila 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 44
지난 30일: 154
전체 시간: 8,075
