주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo ThinkPad X1 Yoga 2nd Generation은 2017년 봄에 출시된 14인치 노트북으로, 모델 번호 TP00076C로 식별할 수 있습니다.
USB C ports non functioning at all.
Is there any way to replace these parts so i can charge it again?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Hi
Have you checked the status of the USB-C ports in Device Manager, you didn't say?
의
its dead atm cause i cant charge so i cant check, its a gen 5, for some reason this option is not avalible , any replacement parts?
의
댓글 달기
답변 2개
선택된 해법
Hi,
You may be out of luck as far as easy replacements are concerned as the two USB-C port are hard mounted on the motherboard.
Are the ports physically damaged at all?
If not then it may still be a software problem and it may be easier to temporarily replace the battery with a fully charged compatible replacement battery and check the status of the USB-C ports rather than removing the motherboard and to replace the USB-C ports as they may not be faulty.
Here’s the hardware maintenance manual that may help with either option that you decide to go with.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I had one c drive fail. It was covered under warranty. They replaced the motherboard. Apparently not uncommon problem. I WATCHED part of a one and half hour video as someone repaired the port with welding equip or something. It was not an option for me.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Yahir Nava 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 22
전체 시간: 902
