Installed the new dvd drive for wii per guide, it loads and ejects disc but does not spin disc at all. Once disc is loaded it makes 3 clicking sounds then nothing happens.
이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 2개:
Is this a known working drive? If so, I recommend you take the unit apart, remove the drive and then test with the machine open. If it's works, then there is a screw or something pressing against the drive. If it does't work, you'll need to check the drive (either using another laptop or another Wii)
DunCanP 의
you can also try replaceing the ribbon cable or the other one
keith s.b 의
