주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Electrolux 냉장고 수리 안내서, 서비스 정보 및 문제해결 도움말입니다.
My freezer not staying cold
i have an electrolux fridge model wwtr1802kwe. When my compressor runs my freezer freezes to -17 or so. After it shuts off over time my freezer goes to like the fridge temp of like 35 This is with the temp set to coldest. So like a fridge and freezer at same temp. I changed the temp control thermostat. I set temp to normal after being unplugged for a few days and it started , ran and cooled normally and after a while freezer warm again. i turned knob to coldest setting and compressor started and freezer cooled ok until over time freezer now warm again . Condenser and evap fans run and coils are clean and no ice in evap coils. Could this be a starting relay controller or starting capacitor problem. The fridge is about 10 years old and i have another the same that works fine after 10 years. They are not really expensive fridges so i dont want to spend a lot to repair. any thoughts would be appreciated..
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi @ehrmy1 ,
There may be a problem with the bi-metal thermostat (aka defrost thermostat), part #21 -system diagram.
The bi-metal thermostat is used to end the defrost cycle so that the defrost heater is turned off and the compressor and evaporator fans are turned back on again to drive the temp back down to the set temps.
The defrost cycle occurs approx once every 10 hours and lasts for about 20 minutes. What happens is that the compressor and evap fan are turned off by the defrost timer initiating the defrost cycle and the defrost heater is turned on to melt any accumulated ice from the evap unit so that it can drain away to the evap pan under the compartments.
The temp in the freezer compartment is allowed to rise to aid in the melting process but usually it doesn’t get any higher than 32 F before the thermostat operates, as you don’t want the frozen food to even begin to thaw.The temp near the thermostat is higher because it is above the heater
Here’s a video that shows how to test the thermostat which may help.
If it is determined that the defrost thermostat is the problem there are other suppliers online that may suit you better as I only linked the above supplier to show the location of the part and also the cost. Just search for wwtr1802kwe parts to get results.
If it isn’t the defrost thermostat it may be the defrost timer part #23 -shelves diagram
Regulates temperature to help maintain proper defrosting in your refrigerator. 이미지
제품
5303918634 - Frigidaire Defrost Thermostat Kit
$33.99
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
The defrost thermostat is good. It closed when i tested it after putting it in the freezer and opened when it warmed up again to room temp,. The thermostat sits on the evap coils and measures the coolant temp coorect. If its low on freon would this affect the defrost? if the defrost timer is bad is the defrost heater on more than 20 minutes or does it prevent the compressor from starting?
@ehrmy1
Low on Freon would mean that it doesn't cool properly i.e not get to the set temps, so either the freezer compartment would be too warm or perhaps both compartments and the compressor would be hot to the touch or at least hotter than usual
I don't think that the defrost thermostat measures the coolant temp per se. it is just that you don't want the evap unit to get too hot and be damaged from the heater which is directly below it as it is only thin Aluminium and the coolant is extremely cold. As the defrost cycle occurs approx. every 10 hours there is not that much ice build up if everything is working OK so it doesn't have to take long to melt it all
If you look at the wiring diagram in the parts link I posted then the defrost thermostat will prevent the heater from operating after the thermostat has operated but the defrost timer contacts may stop the compressor from restarting. You may have to catch the fridge in defrost mode and then check if it restarts OK at the end of the cycle.
If the compressor and evap fan are both stopped for >15 minutes then it is probably in defrost mode (except perhaps in the middle of the night when there is not much user activity i.e. doors not opened a lot, so that the cold air is lost and has to be replaced, so no need for the compressor to run) but the fridge should restart again if more than 35 minutes have passed since you first noticed it was stopped especially if you gently open a door.
I say gently because if the timer is the problem the vibration from opening the door maycause the timer contacts to make again and start the compressor. The evap fan won't start because a door is open. It only works when the compressor is running and the doors are shut.
If it is still stopped when you open the door (>35 minutes) tap the timer and check if this causes the compressor to start
Unfortunately I don't know how to 'force" a defrost cycle in your model so that you can more easily check
I will try changing the defrost timer first because obviously something is keeping the compressor from starting. The fridge is in my shop so it is hard monitoring the defrost cycles. initially after being unplugged for a while changing parts etc it runs normally but it seems odd that i can get it(compressor) to start by turning up the control temp to max from normal at the start but the same thing happens again when the temp is at max. that is the compressor wont start again because i cant turn the temp up anymore
@ehrmy1
The compressor operating circuit goes through both the defrost timer and the temperature control thermostat so it could be either one that is preventing it from starting.
What happens if instead of turning the control temp thermostat from normal to max if you turn it from normal to min and then back through normal to max again, does the compressor start? If so it may be the control thermostat. Apologies if you've tried this already
During the normal course of operating when the refirgerator reaches the set temp the compressor and the evap fan should turn off and then restart again maybe a few minutes later when the temperature has risen above the set threshold in the compartments and it needs to be driven back down again to remain within the parameters of the control thermostat's lower and upper temperature limits.
Basically the compressor should cycle on and off (with it being on longer than being off due to doors opening etc) to maintain the temperatures within the operating limits and should only be off for a prolonged time (in comparison to the other "off" times) during the defrost cycle or perhaps overnight when there is less activity and therefore less need to operate the compressor to maintain the temp as the temp is more stable.
If it does this OK then I'm thinking it is more a defrost timer problem as it only has to restart the compressor once every 10 hours after a much longer compressor off time.
Did you try tapping the defrost timer (part #23 - shelves parts diagram) when the compressor has been off for a prolonged time i.e. 30 minutes, you never said?
In the end you may have to get technical and use a Voltmeter to see if there is voltage at the compressor when it should be operating and it isn't. If there is no voltage being applied to the compressor then you have to start tracing it back to find out why not.
There is a wiring diagram in the parts list I linked although admittedly it is hard to read as it is faint but it's better than not having one
댓글 달기
답변을 추가하세요
Chris Ehrmantraut 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 9
지난 30일: 29
전체 시간: 439
