주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Latitude 7350 하이브리드 노트북(모델 번호: Latitude 7350)은 노트북과 태블릿으로 모두 사용할 수 있는 2-in-1 기기입니다. 2015년에 출시된 Latitude 7350은 현재 단종되었습니다. 이곳에서 수리 안내서와 기기 정보를 확인해 보세요.
Overheating Issue In Google Meet
Every time I load up Google Meet, the back of my laptop keeps reaching hot temperatures. It’s not just a one-time thing, it happens every single day. I’m not sure why this happens but, I've done some digging and I found that the battery and everything is located on the back of the screen.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi @zeku_ ,
Not wishing to pry but how many tabs are open at the time on the laptop or how many participants are there when using Meet?
Here’s the system hardware requirements for the software - see hardware recommendations
According to the specifications that I could find online your model has only 4GB of memory
It may be that your PC doesn’t have sufficient memory to cope and it is only coping by utilizing all the resources it can and this creates heat.
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
I have 2 tabs open, G-Mail and G-Meet. There are around 36 members in there. The settings are 360p receive and 360p send. My laptop has 4 GB Ram and also 2 cores. My friend's recommended 8 GB Ram and also 4 or more cores.
의 공유
@zeku_
Looks like your model has insufficient ram to prevent it getting hot when using Meet
Unfortunately the ram in you laptop is hard mounted on the motherboard so it cannot be upgraded.
The laptop either came with 4GB or 8GB so the only way to upgrade it is to replace the motherboard or get another laptop with better hardware specifications and that can also be upgraded to cope with future software requirements.
8GB of ram is about the minimum default value these days to cope with all the software and also a 64-bit OS i.e. Win 10 64-bit and not Win10 32-bit as -32bit OS only recognizes 4GB ram anyway
의 공유
I upgrade it to 8gb ram it works great now with minimal overheating.
의 공유
댓글 달기
답변을 추가하세요
ZEKU 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 16
전체 시간: 868
