주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo IdeaPad Yoga 11S는 11.6인치 멀티터치 디스플레이를 탑재한 2015년형 2-in-1 컨버터블 노트북입니다.
How can I replace the CPU?
Mainly title, old device and seeing if I can revive it. Can’t figure out where the cpu is much less how to replace it.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi,
You cannot replace the CPU as it is hard mounted on the systemboard. The only way to replace it is to replace the systemboard.
The best that you can do to improve performance is to increase the ram up to 8GB which is the maximum supported by the laptop, if there isn’t this much installed already. You’ll need a 1 x 8GB DDR3L- PC3-12800 SODIMM module
Here’s the hardware maintenance manual for the laptop.
Go to p.39 to view the necessary pre-requisite steps and then the procedure to remove/ replace the ram.
On p.49 are the steps to remove the fan and heat sink assembly. You will find the CPU mounted on the board under the heat sink.
If it has never been done since new it may be worthwhile to refresh the thermal paste on the CPU as it must have dried out by now. There are videos on YouTube that show how to refresh the thermal paste on a CPU if you decide to do this. It will help to ensure that the CPU can run cooler as the heat will be transferred away more efficiently
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
PercyTheB 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 29
전체 시간: 824
