주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to replace battery
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
I operated my dell laptop on power only as the battery needed a replacement since a long time.
But now i cannot turn on my laptop, even in power connection.
Is it possible that the damaged battery caused a short circuit somewhere thus the laptop is inoperable?
의 공유
Hi @costas1440
Yes. You should have at least disconnected the defective battery, better still removed it and even better replaced it with a new one.
If you remove the battery the laptop MAY work with just the charger.
의 공유
댓글 달기
답변 3개
선택된 해법
On many of the newer Dell laptops, you have to remove the bottom cover. Dell usually uses ~4 screws to secure the battery. Once you remove all of the screws that hold the pack in, disconnect it and replace it.
Refer to this manual (online edition) to remove the battery.
To show you how to do it on most of these new Dells, I tore apart a 7490 to give you an idea (yes, this IS one of the 2nd HD or big battery models). Sometimes sticking a guitar pick in a corner of your choice as leverage can he helpful as well. These are not my best photos - I take more care in guides; this is more to give you a starting point from someone who has dealt with these bottom clipped laptops in general enough to know a few tricks.
이미지
이미지
이미지
이미지
이 답변이 도움이 되었나요?
점수 2
댓글 달기
https://www.youtube.com/watch?v=yqQao1zc...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hi buy a new battery pack of the same model Del 5000, remove the old battery pack and insert the new one.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Have battery, how do you open case to replace battery.
의 공유
댓글 달기
답변을 추가하세요
Bonaventure Group 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 51
전체 시간: 2,448
