주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
13" 알루미늄 유니바디, 2.0 또는 2.4 GHz Core 2 Duo 프로세서.
MacBook Pro not turning on
Have an old MacBook Pro 13-inch mid-2008/early-2009 (the one with the two-part bottom).
It’s not turning on, the charger turns orange, but trying to reset the SMC doesn’t appear to work, as I don’t get the confirmation blink turning to green.
What do: This is an ‘as is’ computer I bought, so don’t have a lot of history on it except the owner claimed it worked when he last used it. Was stripped of RAM and HDD, so I put them in.
No beeps when trying to start. Nothing! Not powering on at all, but charger indicator is Orange.
Edit: Could this be the problem?
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 7개
one more detail, the three long screws at the back are missing, and instead are the small screws. Unsure if I can replace with 'newer' 14mm screws from the 2009+ models of the same make.
의
With the computer open and sitting on a table in from of you, look at the left hand side of the top case (the component which houses the keyboard and trackpad). You should see a small gray button with about 8 perforated holes next to it. Press that small gray button. Do the perforated holes light up? If so, how many lights does it show? (This indicates the charge of the battery and can help us determine whether or not the battery is completely drained).
의
I'll try later, but it's been laying bare for several years, so I'm pretty sure the battery is drained. It should still turn on though, yes?
의
There was no 13" model with a split bottom cover (able to replace the battery without taking the bottom off) I've corrected the model info to the 15" model which does.
의
I'm sorry, but I'm actually looking at a 13-inch right in front of me that has the split bottom..
의
댓글 2개 더보기
댓글 달기
답변 3개
가장 유용한 답변
On the Left side is your systems battery checker
이미지
With the charger disconnected what happens when you press the button? Do you see the small 10 LED’s? Are only a few lit? Are they blinking?
이 답변이 도움이 되었나요?
점수 2
댓글 7개:
I'll have to check later. Thanks!
의
Nothing. No light light up when I push that button.
의
Time to replace the battery! MacBook Unibody (A1278) Battery. You also may need a new MacBook Unibody (A1278) Battery Connector as the contacts often failed on them.
의
Right. Could I get the machine to start if I completely took out the battery, you think?
의
Ok, so, found the culprit with the battery. There was a slightly loose connector, (I think that was the DC one), I plugged it all in, and suddenly the battery blinks when pushing that side one.
However, the machine still does not start. That also goes for when not having battery in.
Starting to wonder if the keyboard and power button simply isn't properly attached. Which connector is that?
All other connectors seem to be fast. Gut feel definitely is that it's not registering my keyboard or power button push at all
의
댓글 2개 더보기
댓글 달기
To bypass the keyboard and attempt a spontaneous reboot, disconnect the battery and mag-safe. Press and hold the power button for 10 seconds. Reconnect the battery and then then mag-safe and if all is well and you have some charge in the battery, it should spontaneously reboot.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Will try. Going to post a picture in edit of a cable I suspect may be the problem in a sec. Input would be appreciated.
의
No on the spontaneous reboot. Is it possible the power-button is not connected?
의
댓글 달기
get some isopropyl alcohol and make sure the board is clean - use a magnifying lense to check all over
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I doubt that will matter here. The first step is to see if the system spontaneously starts up after doing a hard reset as Mayer wrote. If that worked the battery needs to be charged more likely replaced.
If the system won't start that's a logic board issue which might be a simple blown capacitor but it will take some effort to trace out the power rails to discover what failed and then getting the part reviewing the schematics and board view drawings.
의
댓글 달기
답변을 추가하세요
Opti 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 30
전체 시간: 406
