주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
러닝머신은 제자리에서 걷거나 달릴 수 있도록 해주는 운동 기구입니다.
Treadmill Motor control board bad?
My NordicTrack treadmill will power up and start fine but after 2 seconds the belt stops moving. The display is on but will not respond when I push the buttons. Once I power off and on it will again start but only runs for two seconds. I have checked the magnetic speed sensor and that is fine. I have also checked all the connections. When I look at the motor control board the red light is on u til the belt moves, then it blinks and goes back to solid red once it stops. Do you think the control board could be bad?
Update (03/12/2021)
The model is a elite 9500.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 7개
가장 유용한 답변
Its a power supply failure
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Yes your controller is probably bad. The way to know for sure is to attach a multimeter to the leads on the circuit board which connect to the drive motor (the motor with the drive belt that connects to the front roller). Set the meter to DC volts and should read over 40. It probably won't show any voltage once the treadmill stops. If it shows anything less than 10 volts DC then you have a bad circuit board.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
That sounds like a current overload problem.... so test the machine without any load .... if it takes more time to shut down without you on it .... you might have to consider changing (or bypassing) a small switch-like device near your power cable on the machine.
Other chances are that your treadmill is showing an error code without you noticing .... is it showing anything on the screen
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Might be a failure with the power supply, but what I would do is take a look inside and compare it to images online and see if anything looks different than a regular one. Might be some loose plugs inside, I had this issue once with a different brand, and it was a loose plug inside that caused the problem.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I thought ifix teach u to repair stuff but here is only guys that have lil experience in repair have no experience in spending and replacing
댓글 달기
It is probably a bad lower control board. Test it by unplugging the two wires leading to the motor and connecting the multi meter leads to the output for the motor, (these should output 10 to 100 v DC). Hit start on the treadmill and if the meter readings are out of range your lower control board is bad.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
the motor is not working
이 답변이 도움이 되었나요?
점수 0
댓글 달기
treadmill.gwey pcb reparing
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Demetria DeBartolo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 24
지난 30일: 115
전체 시간: 2,292
