주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
AGB-002로도 알려진 GameBoy Advance 게임용 게임 카트리지 수리 정보입니다.
Can copper contacts be repaired
so I have an authentic copy of Pokemon sapphire that only works here and there as such I have taken to keeping it in my spare gameboy for now but can the missing copper contact be repaired? I would likely look for a pro as I have never soldered anything myself
Update (03/22/2021)
이미지
이미지
doesn't appear to be working for some reason not sure
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
It's unlikely a game with missing copper contacts would play at all. I'd say the contacts are just dirty. Take an eraser/rubber and rub the contacts to clean them. Should fix the issue. If there really are missing copper contacts i would need to see a picture to help you further.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
you should be able to upload the pictures in your replies directly to ifixit. makes it easier to show the pic
의
댓글 달기
It doesn't look like any of the contacts are missing but seems like the plating on a couple contacts has started to wear off. So long as the actual pad itself is not lifted or eaten away it is possible to replate the contacts, using an electro plating process. I've even seen people put a very thin coat of solder over a contact to keep it from corroding, though that isn't something I would recommend. It might be cheaper and less time consuming to just purchase a new copy than replating your current copy if you do not already have the tools and materials. You could even order replacement PCBs and swap over all the components. I found a listing on PCBWay.com specifically for pokemon GBA games listed as AGB-E02-20 | Game Boy Advance | Replacement PCB
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
thanks I was pondering having a professional fix it anyway as they know what they are doing better I would you still say is better to move the parts to a donor board or replace because from what I know the cost was estimated by 1 company to be about the same to fix up the contacts as to buy a new copy
의
댓글 달기
답변을 추가하세요
Aurora mccain 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 29
전체 시간: 2,635
