주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Cadillac Eldorado의 12세대이자 마지막 세대는 1992년 2도어 쿠페로 출시되었습니다.
Service stability/battery not charging
Just bought 99 elderado.wrecked in back pass.but car has ran beautiful for 1 month I've owned.today on panel it said change oil/check oil level/ service stability/ and battery not charging…ALL AT SAME TIME..As I left grocery store.it made it 11 blocks to home where it died..i have no one to help so hopeing after I go out and jump it with jumper box i can figure out steps to do next..any help/advice for girl who knows nothing but im quick learner .
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi @elderado_99 ,
If you have a DMM (digital multimeter) you can check that the battery is being charged correctly.
With the engine not running, connect the meter across the car’s battery terminals and measure the battery voltage. A good battery should measure ~12V DC. Anything <11.5 is not good.
Next, disconnect the meter from the battery and jump start the car and then with the jump starter disconnected and with the engine running, connect the meter across the car’s battery terminals.
Be safety aware when you do this as the engine is running! Ensure that the vehicle’s transmission is in Park (or Neutral if MT) and that the handbrake (aka emergency brake) is firmly applied
You should measure somewhere between 13.8-14.5V DC.
If you measure <13.8V DC then the battery is not being charged correctly and there may be a problem with the alternator or the voltage regulator.
Also check that the fan belt (serpentine belt?) is tensioned correctly and not slipping or broken just in case. Do this with the engine off of course ;-)
I’m not sure if the voltage regulator in your model is fitted in the alternator or is separate from it. With a lot of cars it is replaceable but is fitted in the alternator itself.
If you measure >14.5V DC then the battery is being overcharged and can be damaged and will eventually fail (boils dry and the plates can buckle etc).
If you don’t have a DMM or know someone who has one, then take your car to an auto electrician or vehicle battery replacement service centre and get them to check if the battery charging is OK. Usually most will do this test for free.
Hopefully a start to find out what’s wrong.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Tammy Bush 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 36
전체 시간: 999
