주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy A71은 삼성전자에서 출시한 갤럭시 A 시리즈의 Android 스마트폰입니다. 2020년 1월에 출시되었습니다. 버전: SM-A715F/DS, SM-A715F/DSN(글로벌), SM-A715F/DSM(러시아).
A71 Power Connection Port
The power port/plug-in on A71 does not connect properly. I have tried several cables, but the phone doesn’t have that little snap/click anymore and the cable may or not be connected for charging. It also seems to have become progressively worse. Can this connector plug in be replaced?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
선택된 해법
Hi @lawstn ,
The easiest option is to replace the USB charging dock board (supplier example only to show part and possible cost).
Here’s a video that shows how to replace the board. The board can be seen being removed at 2:56 minutes into the video.
There are other suppliers online that may suit you better. Just search a Samsung Galaxy A71 USB charging port dock connector board.
If doing this yourself seems too daunting, contact a reputable, professional mobile phone repair service and ask for a quote.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I had a problem with my Galaxy A71 USB-C port and intermittent charging. What I thought was a bad phone charging port, since it acted the same way with multiple cables, turned out to be nothing more than an accumulation of "pocket lint". in the port. Careful scraping with a wooden toothpick followed by a blast of canned air rendered it like new again!
의 공유
댓글 달기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
It’s full of dust and needs cleaned out. That’s why your not getting that click to confirm the chargers in correctly. Use something with a fine tip to remove the debris keeping away from the pins in the centre. If your not confident find a shop to clean it out for you.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Rick 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 20
전체 시간: 1,776
