주요 콘텐츠로 건너뛰기
The Xbox Elite Wireless Controller Series 2 was released on November 4, 2019, and is compatible with the Xbox One, X, & S consoles as well as PCs running Windows 10/11. Model 1797.
20 질문 전체 보기
Issues with bumpers, x/y/a/b buttons
Tentatively opened my Xbox Elite 2 as it’s outside of warranty so I’m unlikely to get much out of MS at this point.
I have little to no response from both bumpers, and spotty response from my A button, so I’m opening it to see if there’s any obvious issues that I can solve.
As soon as I opened it I found a loose screw stuck to one of the paddle magnets, but no obvious hole for it. I think it’s a T5 – it’s very small. I’m not sure if it’s something that got left behind from the manufacturer or if there’s a job it’s supposed to be doing.
The bumpers look like they’re depressing fine when I press them with the front casing removed, so I’m not sure what the issue is.
Any advice would be very much appreciated.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 2개
I would try cleaning the A/B/X/Y contacts with isopropyl alcohol.
I’m not sure where the screw would come from… I’m not as skilled in Xbox equipment.
I don’t quite know about the bumpers either since those are soldered on buttons. my only idea is that the bottom board is bad. (the one without the sticks) But again, I’m not as skilled in Xbox equipment, so I don’t know if that is the problem.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I had the same issues with my bumbers. I took the controller apart and sprayed it with electronics cleaner (amazon). It fixed my issue. Let the cleaner dry all the way before you power it back on.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Georgia 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 25
전체 시간: 4,060
