주요 콘텐츠로 건너뛰기
Hi, I am unable to power on
Unable to power on my laptop,even after battery removal
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개:
What happened before it wasn't turning on? did it power off suddenly or after the battery drained?
i had the same problem - i could not power on, and had difficulty powering off completely. the power button was flashing slowly along with the caps lock key - the screen was pulsating gently at the same rate. when the mains power was plugged in it would power down completely if i held the power button down, but would not power up.
any way - i loosened all the screws and took off the bottom to see what i could see - and that fixed it!! so i gave it a small clean and pressed one or two things in place in case it was a poor connection - it is now running again.
댓글 달기
답변 1개
Hey Wow,
Are there any indicators when you plug in in to AC power?
Do any lights show up?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
WoWsOmE ViN 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 15
전체 시간: 352
