주요 콘텐츠로 건너뛰기
Released in 2008. Will have model number KDL-52W4100 the bottom right corner on the front.
3 질문 전체 보기
intermittent horizontal lines on bottom quarter of screen
Sony KDL55W65: Getting intermittent horizontal lines on bottom quarter of screen. 2 seconds of lines, then 2 seconds of normal. Maybe a loose connection? Repairable?
This is a Sony KDL55W65. I chose Sony KDL-52W4100 because it was the closest option.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
loose connection possible. But a loose connection would not repeat an on/off cycle 2 on/ 2 off………..
each section of the screen is driven separately. It sounds like the circuitry for that section has a problem.
It is probably fixable by replacing the driver board for that section (though the board may include all sections). You need to look at whether it is worth the part and time/effort. The part might be used (cheaper) and the rest of the TV my have a smoldering problem (bad capacitors). There is no warranty on anything. New TV will have some kind of warranty.
There may be a Sony specific community forum that will have the exact problem and more info.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
This is helpful - thank you very much, Bill
댓글 달기
답변을 추가하세요
Phil 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 10
전체 시간: 233
