주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Envy 14-u 시리즈에는 14-u000 및 14-u099 모델이 포함됩니다.
LCD has no backlight even with replacement
My LCD has no backlight even with the replacement. I’m suspecting blown fuse, but I couldn’t find one to test the connectivity.
Do you guys know what’s the fuse looks like on this board.
Update (07/03/2021)
이미지
이미지
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Anan Th. what is your computers complete model number? Do you see any numbers on the board that would give us an idea who made it :-) Check for some printing around the memory modules something like DAY11.......or similar. Also, you need to check the underside of the board as well. There will be components etc on there as well.
의
댓글 달기
답변 1개
가장 유용한 답변
Hi,
Check that the lid switch is working.
Your model has a sensor on the power button board (part # 767254-001 - supplier example only)
I don’t know if the sensor is a magnetic type or a light sensor but you could try running a magnet around the power button area to see if that affects it at all.
Normally when the laptop is turned on, there is power to the backlights all the time and the backlight power is turned on and off in the display panel by the lid switch signalling the BIOS which signals on the blon lead to the display panel.
Here’s an image taken from a motherboard schematic which may not be your board (it’s from a HP Pavilion/Envy 14″ 15″ 17″ Quanta Y11 Y11A Y11C DAY11AMB6E0 schematic so hopefully similar concept) to show how it works. The connections may be different on your board.
이미지
(click on image to enlarge for better viewing)
Here’s the maintenance and service guide for the laptop, taken from this webpage go to p.46 to view the necessary pre-requisite steps and then the procedure to remove the power button board
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Anan Th. 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 16
전체 시간: 701
