주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Chrysler PT Cruiser는 2000년부터 2010년까지 5도어 해치백, 2005년부터 2008년까지 2도어 컨버터블 차체 스타일로 Chrysler에서 국제적으로 제조 및 판매한 전방 엔진, 전륜 구동 방식의 소형 패밀리카이자 소형 MPV입니다.
Pt cruiser limp mode
Where should I begin to look for the cause?
This is really strange , my car shifts gears fine until I hit a good bump along the street. Once it hits a couple manhole covers or potholes the dash display flickers once or twice and the transmission stops shifting past second gear. I do not believe this is a mechanical problem because it always seems to happen when there's a few bumps or potholes? Has anyone had this problem and how did you find the issue? Where should I look,it strikes me as an electrical problem?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
Hi,
Get the OBDII port scanned for any fault codes.
This may be a good place to start to find out what is happening when the car is in limp mode.
I've read that some auto parts retail chains in the USA will do this for free
의 공유
댓글 달기
답변 4개
가장 유용한 답변
as previously mentioned in a comment, get the codes read. In the USA places like autozone and O'Reilly will do this for free. See what it says. The fact that a bump causes it tells me its almost certainly electrical. Loose grounds or plugs are likely culprits. Its going to suck, but you'll need to start chasing wires and double checking everything until you find the cause. Could be electrical connector to the transmission.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
It is an electrical problem, it starts from the connection that reaches the transmission and sees separating the cables, it is probable that some have been damaged and they are making a short, it already happened to me and I solved it that way, with patience separate and if there are stuck cables, peel them off and tape them
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Check the electrical connectors at the pcm and Tom under the hood
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I too have a 2002 cruiser. My transmission stopped shifting gears out of no where . I was stuck of stupid until someone suggested that i change my transmission filter (never even heard of it,but yes it has one) once i changed it and the fluid itself. I have not had that problem since
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Margaret Groot-Koerkamp 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 23
전체 시간: 2,077
