주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1.7 GHz 듀얼 코어 인텔 프로세서 (최대 2.6 GHz 터보 부스트), 3 MB 공유 L3 캐시
Display not working when using a certain ssd
I was trying to reinstall the MacOs on my old macbook but it doesnt seem to boot anymore with the current ssd. If i unplug it or use a different ssd i can boot.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
What is the SSD's you are working with? Make and Models
의
@danj Im using the original ones that came with it. I believe its a 128GB Toshiba
의
댓글 달기
답변 2개
가장 유용한 답변
I’d boot from an external source, reformat the dive, run Disk Utilizes on it and then try installing a new system from the external source.
This failing, it’s time for a drive replacement:
MacBook Air 11" Mid 2012 SSD 교체
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Even though it was working perfectly fine before? I had reinstalled the OS then it turned off again so i reinstalled after, after that is when it no longer booted. If the SSD is plugged it, it doesnt boot past the chime. If i tkae out the ssd i can do command + R to recovery mode easily
의
Don't try to do a restore from a drive that's not in the machine, The recovery files and your data are all on the same drive. So do the the work on the internal drive from an external.
의
댓글 달기
This SSD has a known issue! Apple issues firmware fix for Toshiba SSDs in 2012 MacBook Airs & Apple Recalls Mid-2012 MacBook Air For SSD Replacement – 64GB and 128GB SSD Systems Affected
Its a bit on the late side, but its possible you just don't use your system that heavily so it took a bit of time.
Sadly, Apples extended warranty program has ended for your system. Time for a new drive!
The Apple SSD is a bit faster than the OWC drive, but its more expensive.
Replace or upgrade the SSD in your laptop. This SSD is compatible with a Mid 2012 MacBook Air 11" or 13" laptop. 이미지
제품
OWC Aura Pro 6G SSD for MacBook Air 11" and 13" (Mid 2012)
$52.99
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jun Hyeok Yoon 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 13
전체 시간: 401
