주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JBL Go 3는 작고 휴대하기 좋은 블루투스 스피커로, IP67 등급의 방수 및 방진 기능을 갖추었으며 한 번 충전으로 4~5시간 동안 재생할 수 있습니다. JBLGO3로도 알려져 있으며, 휴대성이 뛰어난 구조 덕분에 외부 활동 중에도 간편하게 사용할 수 있습니다.
no Red Light while charging
Hi, I just bought a Go3 a few weeks ago, but by mistake my brother at some point put it to charge with a Samsung 15 watt fast charging charger, the speaker works perfect but apparently the red light when charging no longer lights up, everything else works perfect, even the white light is still on while in use. Although it may not be of much importance, but not having the red light does not allow me to know exactly when the battery is low (normally it blinked) or worse, even now I do not know when it is fully charged. So, what should I do? any idea, suggestion? or nothing to do and better buy another? thank you all
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
UPDATE:
After my problem arose, I decided to continue using my Go 3 and completely forget about the failure, then I recharged the battery using its original cable as always but this time connecting it to the USB port of my Mac mini 2011. The red light never ever returned until the today. "What I think is that ... probably when it was erroneously recharged using fast charging from a Samsung cell phone, the battery or charge manager was" out of calibration "(is what I think). several times with the "proper" load, the speaker recalibrated (if what I'm saying makes any sense). Thanks for your help. No need to open the speaker, I was afraid of damaging it.
의 공유
댓글 달기
답변 1개
@hotdavesweet sounds like there are issues with either the battery or the power management IC. I would take a look that the board and check for obviously damaged components and at minimum replace the battery. Use something like this video to work on it. As always, if in doubt or unsure of what you are looking at, you can always post some good pictures and we will try to assist you.
기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
Thank you, I'll check inside. The video is for Clip 3, mine is Go 3
의 공유
@hotdavesweet sorry about that. Use this one instead.
의 공유
Thank u so much
의 공유
댓글 달기
답변을 추가하세요
hotdavesweet 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 19
지난 30일: 66
전체 시간: 4,225
