주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
6.01인치 AMOLED 디스플레이를 탑재한 안드로이드 스마트폰, OnePlus 5T에 대한 수리 안내서 및 지원 정보입니다. 2017년 11월에 출시되었습니다. OnePlus 5의 후속 모델입니다. 모델 번호: A5010.
Replugging screen : upside-down and multiple
Hello !
I just received a new screen to replace my broken OnePlus 5T screen. I thought it would be easy game : dissemble, plug and done.
However, the result is not quite what I expected. The screen is upside-down and displays two times what should appear once (as you will see attached). Also : the touch screen is at the right place, as if nothing was different from a new phone with perfect display…
Have I done something wrong… ? Do you have any solution?
Many thanks in advance !
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
KasDing the only thing you want to check on is your connector. Make sure that the pins are straight and not bend sideways etc. Ultimately this sounds and looks like a bad screen. Return it to wherever you bought it from and request a new display.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Hello oldturkey03 !
As you said something could have been wrong with the pins, but surely the screen was down.
I returned it and got another which works perfectly :)
Thank you for your help !
의
KasDing glad it worked out for you! Keep on fixin'.....!!!
의
댓글 달기
답변을 추가하세요
KasDing 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 15
전체 시간: 511
