White light blinking then fading
Why is the white light blinking then fading to off and the television does not come on when I press the power button?
좋은 질문입니까?
좋은 질문입니까?
@orchid28 that is because your TV does not pass its own POST (Power On Self Test). It appears that one of your boards is not providing the feedback needed. Vizio is a bit of a different brand and uses a hodgepodge of parts. You will have to remove the back cover from your TV and check the boards for obvious damage. Make sure that all the ribbon cables are properly attached since Vizio has issues with bad connectors. Your issue is most likely power board-related and you would have to measure the connection t the main board to ensure it provides proper voltages. Post some good pictures of your boards so we can see what you see and we can try and provide more guidance to achieve a good outcome. 기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 6
지난 30일: 22
전체 시간: 4,641
