주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
CB 라디오(모든 유형)는 1958년에 처음 도입되었습니다.
CB Radio not functioning - white noise only
I’m trying to get a CB radio (~27MHz) up and running but I’m a bit of a novice. I believe I have the correct equipment, but on all 40 channels I only get white noise of varying strengths. I live in the middle of a city so I would expect to hear something. I will list my equipment below in hopes that that is the issue, other wise I am open to any troubleshooting steps people have in mind. Thanks in advance!
Radio: Uniden PRO505XL - Amazon page no longer exists
Power Plug: Roadpro 12V Fused Replacement Cigarette Lighter Plug with Leads - RPPS-225 - https://www.amazon.ca/gp/product/B0016LG...
AC to DC Adapter (for use in house): AstroAI AC to DC Converter, 10A/110Vto12V DC/120W/7.78FT - https://www.amazon.ca/gp/product/B07JGS8...
Antenna: Bingfu CB Antenna 27MHz CB Radio Antenna Soft Whip Magnetic Base CB Antenna BNC & PL259 - https://www.amazon.ca/gp/product/B086YYW...
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
A few extra notes:
- I have turned on the radio without the antenna connected and I do not hear anything. I would think this rules out electrical interference.
- I have plugged in an external headset and get the same results, so I believe that rules out an issue with the internal speaker.
- I have tried placing the setup in my basement, outside my house, and in my garage. No luck in any location.
- My antenna is new, so it is unlikely to be damaged. My connections are in good condition.
- I have taken the cover off and looked inside; no obvious signs of damage (I can send a picture if someone desires)
댓글 달기
답변 2개
가장 유용한 답변
3 easy steps to install a CB radio. Step 1: mount your antenna and coax. Step 2: Route the coaxial cable. Step 3: connect to a power source.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
you have the wrong type of antenna setup.... you will need 18ft coax cable and antenna mount, with a descent antenna...( approx. 3ft.) fiberglass rod style or a magnetic base mount, ie. wilson "lil wil" or a K30 mag mount.... these both come with pre-installed coax cable. you will need to set the SWR's on the antenna to a 1:1-1.7 on the meter that you use. the closer you the match, the better... good luck!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Emery Dlugan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 19
전체 시간: 585
