주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
4세대 iPhone의 CDMA 버전에 대한 수리 정보 및 안내서. 모델: A1349 / 8, 16 또는 32 GB 저장 용량
Logic Board Rubber Bumper Location?
I replaced the display assembly this weekend, but when I was attempting to reinstall the logic board (step 21 of the guide, in reverse), a small rubber bumper came loose from 'somewhere' on the board (I think).
Here's a picture of the bumper (with the broken screen as a backdrop to give you a sense of proportion). Can somebody identify where it belongs? It's seldom good when you've got parts left over!
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 4개
선택된 해법
It goes on top of the Logic Board, under the two Front Screen Flex Cables. I have seen a couple of iPhone 4 without this installed or just missing and they functioned perfectly.
이 답변이 도움이 되었나요?
점수 8
댓글 2개:
That was a huge help. Thanks!
의
댓글 달기
Also, notice there is a thick and thin side to the bumper, and the thin side should be on top, or toward the back panel.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
That little plastic bumper folds over the top of the logic board assembly where the Digitizer ( Front Panel) cables come up and over. If you look close at the bumper there is a small grove that is the same size as the boards thickness. Its just there to protect the Digitizer's cables from the rough surface of the logic board.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thanks for that info... Super helpful
의
댓글 달기
what would happen if you were to put this on the wrong way
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Matt Strange 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 20
전체 시간: 7,823
