주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Aquos LC-13B2UA는 Sharp에서 제작한 LCD 텔레비전입니다. Sharp Aquos LC-13B2UA의 크기는 13x3인치입니다.
Plugged in and popped
Plugged in and popped, now doesn't turn on. We found out that all our outlets in our basement were getting too much power. I haven't attempted to fix, figured TV was done. I thought this site might give me some answers. I have no problem taking it apart if it can be fixed…is it worth it or a lost cause?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @cindylee ,
Just verifying that the TV is an LC-13B2UA?
If so, looking at the user manual for the TV it has an AC/DC power adapter which supplies 12V DC power to the TV.
If the power outlets were supplying too much power the adapter may have failed and not the TV.
Plug the adapter into a power outlet only and check if there is 12V DC when measured on the output plug of the adapter.
If the adapter output voltage is OK you have to remove the back cover from the TV and inspect the board where the power plugs into. Check for a blown fuse or surge suppressor (images to show what they look like) near the power input or other blown components on the board.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Cindy Houston 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 343
