주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Skullcandy Hesh 2는 Skullcandy에서 판매하는 블루투스 무선 오버이어 헤드폰입니다. Skullcandy Hesh 2 모델은 모델 번호 S6HBGY-3xx로 식별할 수 있습니다.
Is the battery replaceable
Has any one replaced the battery in these headphones? I can’t seem to find any guides on how to replace it. I would hate to throw out a perfectly good pair of headphones.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 3개
선택된 해법
Those internal photos was exactly what I was looking for. I got the part number I was looking for. Thank you so much. I wanted that info before opening it.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Christopher Eckersen that's awesome. Best of luck to you and don't forget to make a guide
의 공유
댓글 달기
가장 유용한 답변
Christopher Eckersen  there are not clear cut guides yet. Now it’ll be up to you to become the Pathfinder and create one. Yes, the battery can be replaced. Never easy since they (manufacturers) do not want us to fix things. With these headphones it’s actually straight forward. Basically, you remove the earpads. After that remove the four screws that hold the driver to the housing. The battery is behind the speaker nestled into the headset. I suggest you check this video (it’s dreadful but has a bit of valuable information on how to remove the drivers (speakers). Use this document Internal Photos 2316351 for the rest of it. The second picture shows you the battery etc.
This https://www.ifixit.com/Guide/new will help you to create a guide. It would be awesome for the next people that are looking for how to replace the battery.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
The Replacement Battery for the Hesh2 is JHY602535 3.7V 450mAh 1.67Wh found on eBay for $5.99USD Shipped. You need to Solder the Positive & Negative Leads.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Did you upgrade your mAh while you were at it? If so do you double the current size or go for the biggest one that fits?
의 공유
댓글 달기
답변을 추가하세요
Christopher Eckersen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 12
지난 30일: 66
전체 시간: 6,097
