주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
메모리 업그레이드 및 뒷면 커버 분리 방법 모델 번호 21-h010
One red line occurs frequently
A red line flickers on the screen frequently.
이미지
But it doesn’t appeare on white background
이미지
(Red lines appear over the dark region. but the white lights works properly)
Can someone provide a guide to fix it in HP All-in-one 20-r141in
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개:
A white screen has all the colors on. A black screen has them all off.
That line segment is not turning off the red and is likely a connector issue, but could be the screen or drive circuitry. None of that is a simple fix.
의
@ruggb Any possible guidence if it is a connector issue?
의
You must open the computer up, find the connectors leading to the monitor and for pin type, disconnect/reconnect them, maybe a few times to clean the contacts. In the case of flex cable connectors, rubbing the contacts on the cable gently with a pencil eraser. There are also connectors behind the monitor which are much more difficult to get to.
The trick for the flex cable connectors is not to break the connector when opening. They are very delicate but they do open easily if you are doing it right. Refer to youtube videos. If cleaning connectors does not solve it, then it is either a deteriorated cable with an open trace or a bad monitor.
의
댓글 달기
답변 1개
This is probably a bad ribbon cable or the ribbon cable has come out of the holder a little. either way first step is usually to reflow the solder by just touching it with a solder pen to melt it and move to next one. check that it is plugged in flush with the locking connectors. If this doesn’t fix it you may have to replace the ribbon if posible or if not buy a new screen from aliexpress or alibaba
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Vikash 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 20
전체 시간: 1,132
