주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Insignia 브랜드 텔레비전에 대한 수리 및 문제해결 안내서입니다. Insignia 텔레비전은 Best Buy에서 독점 판매합니다.
Switch screen into a 15in
Say I have a insignia Fire TV 24in. And the screen is out can I put all the insides of it into a 15in lcd ampd tv and use its screen????if so will u please help me
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Jason Maguire without actually seeing it, I highly doubt that this is possible. First off there should not be any room in a `15” chassis to accommodate the boards from the 24”. Then there is the bigger issue. A 15 panel will most likely not even get recognized. You would need to compare the datasheets for the old 24” panel with the 15” panel to determine if the LVDS connectors are wired identical etc. Most LCD driver boards actually have an EEPROM solder to it which makes it communicate with the main board and the panel so it will most likely not communicate with the 15 panel.
Se if you can find another Insignia TV that is broken in other ways and harvest the LCD from that. You can also try and check the label on the back of the panel. There should be the make and model for the panel on it. Do an online search with the panel number and see if it is available.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jason Maguire 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 15
전체 시간: 338
