주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
ASUS X555QG Screw Sizes
Is there any X555QG documentation on where the screws should be placed? I lost track and now I'm scared of breaking something inside.
I have
4x 9mm
and 6x 11mm.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi @banesrb ,
I couldn’t find any information regarding the locations of the screws in the laptop but here’s a list of all the screws that are used.
There are no 11mm screws in the parts list so presumably they are the M2*12L (12mm) screws.
Perhaps you could use a thin wire and insert it into the screw holes and then mark the wire so that you can measure the depth of the hole. A difference of 3mm between the screw lengths should be easy to discern
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
I guess this will be close enough, thank you.
댓글 달기
답변을 추가하세요
Bane 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 19
전체 시간: 1,199
