주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2020년 4월에 처음 출시된 Google의 개선된 완전 무선 이어버드, Google Pixel Buds 수리 정보입니다. Pixel Buds 2 또는 Pixel Buds 2020으로도 불립니다.
Can you replace the battery?
The pixel buds disconnect whenever they are removed from the case. I think the batteries are bad. Is it possible to replace the battery?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
I'm not seeing replacement batteries for the buds themselves, and the process looks pretty destructive. These aren't made to come apart.
의
댓글 달기
답변 2개
선택된 해법
Hi,
Here’s the Ifixit Google Pixel Buds 2 분해도 guide which shows how to open the ear buds.
The guide was only to show the internal components and is not intended as a repair guide because of the damaging way in which the earbuds have to be opened.
The battery is a Varta CP1240 A3 (supplier example only) if you think that you want to try and replace them
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
If anyone is attempting this repair, I had good results with using a pair of pliers and gently applying enough pressure to bend the plastic slightly to crack the seal with minimal damage to anything else
의
댓글 달기
가장 유용한 답변
I don't believe it is possible to open these earbuds without damaging the casing. Therefore, you cannot replace the battery.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Joshua Stouffer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 22
지난 30일: 78
전체 시간: 9,778
