주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
360도 힌지가 있어 태블릿 형태의 폼팩터로 변환할 수 있는 13인치 "2-in-1" 노트북입니다.
Battery compatible with my device?
Hello, I wanted to confirm that the Dell WDX0R battery listed for the Inspiron 13-5368 would be compatible with the Inspiron 13-5378? The battery is completely dead, so it can be only used on AC power and I wanted to replace it.
Dell WDX0R Battery
Thanks!
Replace a dead or malfunctioning battery for laptops using a Dell model WDX0R battery. 이미지
제품
Dell WDX0R Battery
$69.99
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Dell WDX0R Battery
according to what I can find no they are slightly different but here is the correct battery
제품
Dell WDX0R Battery
$69.99
이 답변이 도움이 되었나요?
점수 1
댓글 13개:
Hi @stressmaster ,
In the link you posted it shows that the battery, model # WDXOR, is compatible with a Dell 13-5368 and a 13-5378.
It's the same battery model number as shown in the image for the ifixit one, so it should be the same or am I missing something?
If necessary the OP can check using this link to check for compatibility using the laptop's service tag. It is also a WDXOR battery
Cheers
의
@jayeff you will notice that that model doesn't show up in the like. I believe it is a Wh thing or a screw placement.
의
@stressmaster The wh just means it will run longer, especially if this battery has a higher Wh rating then the original. The voltage has to match or be in the supported range, but you can upgrade the Wh on a laptop battery.
의
@stressmaster
It can't be a screw placement otherwise what's the point of model numbers?
If they had different model numbers, albeit only a suffix to the model number, then fair enough, that would denote that they're different in some way.
This link also shows that a WDXOR battery is compatible with both models that the OP asked about.
의
@jayeff looks like you're right and it's compatible. Maybe ifix needs to update listing
의
댓글 8개 더보기
댓글 달기
답변을 추가하세요
Auchhior 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 503
