keyboard + other issues
Hello,
I will try to add as much information as I can. The main problem is I don’t know how all the issues are connected to each other.
So, some time ago a problem with key E appeared. Sometimes it didn’t work, sometimes, if push several times it started to work again. Then it could type several E(s). This was a rare case at the beginning. Eventually, mac started to type E at random times, but not when the key is pushed.
So, I bought new keyboard (it looks good, but definitely not Apple) and replaced existing with new one.
1 week everything worked perfect. Then the keys Left Shift, Backspace, Left and Right Arrow keys started to do similar to what happened with E on old keyboard, until they stopped to work at all. (Bad left shift makes it impossible to reset SMC)
At this point I had to clue how to proceed. But even before the keyboard replacement, the battery was pretty bad (1100+ cycles and “Service Recommended“). Sometimes it started to shutdown even on 50% charge.
So, I decided to replace the battery. I just did it. The battery looks like original Apple manufactured battery. The results:
  1. Keyboard still has the same issue - multiple keys are not working.
  2. mac didn’t start at all with new battery, but started after I plugged in the cable. Then I unplugged it, shutdown - and now it does not start at all, with or without the power cable. The charge was about 70%.
Another piece of information: this mac has dual graphic cards. I’m not 100% sure, but it seems dGPU is not working. I tried to force mac to use it and Monitor even showed that dGPU is on, but none of the applications were using it. I’m pretty sure I saw Chrome was using it a long time ago.
There was no spill done to this mac.
What could it be? Dying motherboard? If so, is there a good way to check it?
Btw, I could run Diagnostics after keyboard replacement - no issues were found.
Thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 기존 질문에 이미지 추가하기
I fear your battery is not very good.
의
댓글 달기
