주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Smove mobile battery replacement
I need to replace the battery on my Smove Mobile gimble device it is a Howell 2x902360-1300mah 7.4v 9.62wh battery I need to find a suitable replacement either the same battery or an except-able replacement. I’m fine with soldering the terminals if I can find the same form factor battery.
이미지
이미지
이미지
이미지
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개
I am curious if you found a good solution for this?
@grayraver See oldturkey03's answer
How did you get the SMOVE apart? I have the same issue and want to bring mine back to life
댓글 달기
답변 2개
가장 유용한 답변
You can tape two of these together and solder the batteries onto the wires coming out of the connector in the same way the old batteries were connected to the connector.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Do i need to connect with a parallel connection?
On SMove pictures it shows 7.4v battery, so it looks like we need to connect two 3.7v batteries sequentially.
But connector shows 4 wires - 2 red and 2 black. Does connector actually connects them sequentially?
댓글 달기
@starsoldier420 pretty common battery pack on RC equipment. You should easily find a replacement at sites like this. All you would need to modify might be the connector.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Randy Northrup 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 26
전체 시간: 1,464
