주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP EliteBook Folio 9470m은 하이엔드 개인용 컴퓨터와 유사한 기능을 갖춘 저비용, 경량형 노트북입니다. 2013년 2월에 출시되었습니다. 모델 번호 HSTNN-I10C로 식별할 수 있습니다.
Why can't I remove the battery?
I tried following the battery removal guide, but after sliding the battery latch till the red part is visible, I can't slide the battery out. I've used a credit card to slightly pry the bottom part thinking that it was a friction problem, but it still doesn't come out. What can be done about it?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Chideria Ehirim download the service manual for your computer from here Page 46 has the instructions (just like you did) Make sure that the latch is slid right to the end. You should get the battery to slide out first. You may need a little extra force so try a small screwdriver between the case and the back (not the bottom) of the battery. It has to slide out first before you can lift it out.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
I've tried this and the battery doesn't budge at all.
의
I wonder if the locks move when you move the latch. Do you feel any resistance?
의
댓글 달기
답변을 추가하세요
Chidera Ehirim 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 412
