주요 콘텐츠로 건너뛰기
2010년 중반기 모델 A1278 / 2.4 or 2.66 GHz Core 2 Duo 프로세서
Laptop screen experiencing graphical issues
So the other day I was using my laptop and mid use the screen would freeze and everything would discolour, and there would be this effect as if the screen was freezing cold (like with snow — of course, not actual snow, just a layer of white light). Afterwards, the screen would return to normal, with a slight unnoticeable flashing effect.
However, today I opened my laptop and found that it’s just not working at all. I can’t tell if it’s the display, a GPU error, or just something from the cold?
Soon after booting up, it slowly fades to this.
I have a feeling it’s either the GPU or something to do with the cold weather. I’m not sure.
UPDATE: i put it in front of the heat and the screen loaded up properly, but the moment I pulled it away, it started to freeze white like I mentioned earlier. It’s working fine at the moment, but I have no idea why it’s so sensitive to the cold (the weather here is like 8°C)
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개:
Does the laptop display correctly when connecting it to an external display?
@andrewsawesome i don’t know, i don’t have a cord on me nor do i know if i can get my hands on one, but it’s working fine after i gave it some heat. for some reason it’s sensitive to the cold? i’ll see if i can try getting my hands on a cord to see what the issue is if it goes white again.
댓글 달기
답변 1개
you’ll want to hook it up to an external display and see if the issues persist. If they don’t, it’s a screen issue. If they do, likely it would be a GPU issue.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
yeah, i don’t have a thunderbolt cord atm nor will i be able to get my hands on one, but the screen seems to be working fine now after i gave the laptop some heat. i’m just shocked that it’s so sensitive. if it goes white again, i’ll see if i can try getting my hands a thunderbolt cord, so that i can see if it’s the GPU or not.
댓글 달기
답변을 추가하세요
zak 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 346
