주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony GTK-XB5는 2016년에 출시된 Bluetooth 지원 고출력 홈 오디오 시스템입니다. 이 오디오 시스템은 블랙, 레드, 블루 색상으로 제공됩니다.
does not have sound?
이미지
.See attached image. I have the same issue and I believe the cause is this short on the motherboard where the solder has come off and is touching the other two solder points.
Update (01/20/2022)
Yes sorry same model number Panasonic max2000 it powers on fine. No power on at all.. Tried to reset. Still nothing. I did clean up those points to no avail. it was switched to 110v and powered on when it should have been on 240v.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
connor Hart it is possible. That cleans up relatively well with a soldering iron, flux and a desoldering wick. Looks like it is just used for a wire jumper. We would need to see what is on the other side,. also, let us know your Home Audio's exact model number. Since this was converted from an answer to its own question, the device may not be absolutely accurate.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
connor Hart 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 13
전체 시간: 615
