주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xtreme 2는 2018년 1월에 출시된 대형 휴대용 블루투스 스피커입니다. 이 스피커는 IPX7 등급을 지원하며 최대 15시간의 배터리 사용 시간을 제공합니다. 모델: PL
What does the red flashing led mean?
The red led is flashing below the red jbl symbol. What does that mean? The speaker will turn off as soon as I turn it on while plugged into the wall.
Thanks for taking the time to look at my question, regards Cameron
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi @camthekiwiboy ,
A red blinking LED indicates that the battery is very low and that it needs to be recharged with the power adapter.
If after fully charging the battery, the speaker turns off when operating on the battery only, then there is a problem with the battery and most probably it will need to be replaced.
Here’s a video that may help with this
이 답변이 도움이 되었나요?
점수 3
댓글 6개:
Awesome thanks alot that video was exactly waht I need ???
의
Hey mate did I screw the battery by always having it on charge? Cheers
의
@camthekiwiboy
Most batteries are meant to be used so keeping them on charge all the time actually does them more harm than good over time.
Also depending on the type of battery i.e. lead acid, NiMH, LiPO Li-Ion etc it varies as to how to maintain the battery charged (especially if not using them) so that it is also not damaged in any way.
The speaker's battery management circuit should take this into account but then it is supposed to be a "portable" speaker i.e. not normally connected to external power source, so the battery is expected to be mostly used for powering the speaker
That is not to say that you flatten the battery every time you use the speaker. Just use it normally and try not to let the battery charge drop to less than 30% before recharging back up to fully charged
의
i get that i may have after 2 years toasted my battery by leaving it on charge the whole time, but i just replaced the battery an still have red light turns of problem. WHERE DO I GO FROM HERE?
의
It doesn’t charge even after a long time, keeps showing red
의
댓글 1개 더보기
댓글 달기
답변을 추가하세요
Cameron stone 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 25
지난 30일: 146
전체 시간: 25,740
