주요 콘텐츠로 건너뛰기
Popular laptop sold by HP. While it comes in many configurations, all models of this laptop have the same basic form factor. The numbers after G60 indicate the factory specifications of the laptop and who sold it.
20 질문 전체 보기
Wireless switch stopped working in Linux.
This is a new problem. Wireless worked fine in Linux until two days ago. Now pressing button wont turn it on. Trying with a live disc also doesn't help so I know its not the software. In Windows 7 Ultimate 64 bit, it is acting up as well but still works. In Windows, I have to press the button twice to turn on the wireless card after it boots up and then the switch turns off if the computer is idle for a few minutes. "Allow computer to turn off this device to save power" is unchecked. Why is it doing this and how to fix?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
As you are describing the problem it is not operating system related. I would look in your BIOS for any related setting for the WIFI/Network also for power management. If there is control for power management in the BIOS those settings could cause this.
I haven't changed any settings for a long time now but i will check it out. I have checked all the driver settings that I can think of in Windows and that hasn't fixed it. I also replaced the wireless card itself (not the switch) because I have a parts machine so it was free and easy. That didn't help either so I believe it is a hardware or BIOS issue as you say. I also like that saying "the answer doesn't matter if you're asking the wrong questions." How true!
댓글 달기
답변 4개
선택된 해법
Just you mentioning the need to push the button multiple times says to me it is a hardware problem or system setting in the BIOS that is the problem. The WIFI card should work and be able to be turned on if there is no operating system or drives for that matter installed. If it isn't a setting in the BIOS I suggest you get a USB WIFI card . I got a wireless B/G/N USB card from Newegg a couple of months ago for less than $20 including shipping. So they are coming down in price. I'm getting 250MBs from my N router to my laptop any where in the house now. I volunteer here and am here most days. So I have no problem helping you through this, if I can. But I always try to steer my paying customers to the most economical route, that fits their needs. When you consider time is money, that is what I am trying to do here. It is the same suggestion I would give a paying customer that described the problem as you have and I would do that over the phone and not make a dime off them - this time.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thank you for your time. I replaced the internal card (I have a parts machine) with no change. BIOS/CMOS is very bare bones and I didn't see anything that related to the wireless card so I didn't make any changes except for removing my password. I have USB WIFI cards. The problem is they extend the form factor of my machine out by 5 inches or so and they use up a USB port. I only have two, although i may replace the one that is broken this week.
Here's link to the service manual. It lists all the settings that can be changed in CMOS in case you wanted to look at it. http://www.scribd.com/doc/75366952
댓글 달기
가장 유용한 답변
I HAVE THIS SAME PROBLEM. Over a year ago, WiFi stopped working in Linux, but it did in Windows only if I re-enabled it every time it booted and resumed from sleep. But just minutes ago, it "relapsed" and went back into this weird condition. I hope someone knows an answer. (HP G60-549dx)
EDIT: Through a combination of holding the WiFi button, and toggling it in GNOME, it came on! Ymmv.
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
Thomas, what did you do precisely to get to work in Gnome. I either don't understand what toggling "it" refers to, or maybe the wifi button is different than the button to turn on the wireless? I'm confused but would REALLY like to be able to get it to work again in Linux.
Oh, I just continually tried to turn it on in Network Settings, then holding in the wifi button for >30 seconds, and repeatedly pressing it. The light eventually turned blue and of acted normal, regardless of OS.
Thank you. I'll give that a try. I seem to recall that when my switch is off, wireless is not even an option in Network Settings though so I have to see where I need to go in that applet to turn it "on".
댓글 달기
Here's a definitive and easy fix!
Plug the HP G60 into an ethernet feed so you have connectivity.
In the terminal, type the following:
sudo apt-get install rfkill
then, once you have rfkill, type:
sudo rfkill unblock all
I found this on http://www.linuxquestions.org/ after trying MANY queries.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
I followed something similar. Have your computer on hold the wifi button down for 30 secs. Then let go. Then press it like 30 times and wait like 30 secs. It then suddenly connected to the network. During the entire process the light stayed blue. Nothing signaled to me that it was about to work., but it did. Good luck everyone!
댓글 달기
Simply using rfkill might not have the desired effect. But I've found recommendations what else can be done -- http://superuser.com/a/698649/65570 :
1) First, do rmmod -f ath5k, and then rfkill unblock all;
2) Use the special parameter of ath5k module to ignore the hardware block (because the WiFi-device might receive wrong signals from the button, for example, if the firmware doesn't correspod to way it has been connected, and so on).
3) Suppress the loading of hp-wmi (BTW, what's the purpose of this module? modinfo says: HP laptop WMI hotkeys driver; "The entry for hp-wifi is for the software that monitors the switch."):
** "Workaround #2: Add hp-wmi to modprobe blacklist. Again, this causes only phy0 wireless to be reported and phy0 always accurately reflects the state of the hardware (both soft and hard blocked)."
** "Instead of removing my ath9k and adding it back, I simply removed the hp-wifi module like so. rmmod hp-wmi (do this, this removes the hp-wifi module which you don't need now )"
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Tony 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 7
전체 시간: 4,766
