주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
720만 화소, 3배 광학 줌, 2.5인치 LCD 화면, 2006년 8월 출시
Camera Shows "Lens Error"
The camera powers on, and briefly shows an image on the LCD display. Then eventually it gives a "Lens Error" message.
Has anybody gotten this error before? Know how to fix it, I'm thinking that since the camera shows an image on the LCD, it may be a software rather than hardware problem.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 3개
what error no. does it give?
의 공유
pollytintop, I think it's one of those cameras that just says "Lens Error". Usual cause is sand grid and grime in the rings, a dislodged lens, or faulty lens motor. :-)
의 공유
Any way to fix it?
의 공유
댓글 달기
답변 1개
선택된 해법
If the lens does not extend/retract properly, then you most likely have something stuck in the zoom gears. If the lens extends but you hear a high pitched buzzing noise, it is the focus motor that is the gears are out or your have debris it it. I would start by reading these tips and see what you get. Also take a quick look at this video to see what you might be up against :-) hope this helps, good luck
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Danny Arenales 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 12
지난 30일: 37
전체 시간: 13,696
