주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
초대 Altima는 1993년형 모델로 1992년 6월에 생산되었습니다. 모든 Altima는 2004년 6월까지 테네시주 스머나(Smyrna) 공장에서 제작되었으며, 이후 수요 증가를 충족하기 위해 미시시피주 캔턴(Canton)에 위치한 Nissan 공장에서도 해당 모델을 생산하기 시작했습니다.
has problems starting most of the time
I have a 94 Nissan Altima 4 cylinder that has problems starting most of the time. If I pull a plug out I am getting spark and it allows the car to start, but put it back in then it doesn't start... Help please...
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Dave Scott could be many of things. If it has spark it most likely has spark when it is back in the cylinder head. So that would leave either fuel or air as a possibility. Check your fuel filter and pump to make sure that you have the right fuel pressure on that. The other thing you need to check for is that the spark happens a the right time. So you need to check the crank position as well as the cam position sensors. I would strongly suggest that when it runs, take it where they can scan the vehicle 's OBD to see if and what codes you get. Otherwise you might be spending a lot of money for parts that are not needed. Depending on where you are, places like Autozone do the scanning for free. Let us know what the exact engine is and what you have checked so that we may provide a more in depth answer
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
I have replaced the fuel pump, battery, and fuel injectors it is getting gas, also should note that after replacing each the car started like the problem was fixed I shut it off came out next morning back to not starting, has me very confused. Was going to take it to shop down the road but won't start now..
의
Sorry, forgot to also mention the spark plugs and wires were also changed recently.
의
What about the cap and rotor?
의
댓글 달기
답변을 추가하세요
Dave Scott 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 6
전체 시간: 473
