주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS Chromebook C523NA는 2018년 10월 23일에 출시된 ASUS의 크롬북 노트북이며 Google Play 스토어와 호환됩니다. NanoEdge 디자인을 적용한 최초의 ASUS 크롬북으로, 더 큰 화면과 더 콤팩트한 디자인을 특징으로 합니다.
Can I replace it
it's where the Chromebook charger plugged in
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi,
Which USB 3.2 port are you referring to, the one on the right or the on on the left side of the laptop, as either can be used to charge the battery?
The one on the right side is on a removable board, the one on the left is soldered onto the motherboard.
It seems that there are two boards available for the right side, Asus part # 90NX01R0-R10011 and part #90NX01R0-R10010. They look very similar and I don’t know what the difference is between them. Hopefully the board in your laptop may have the part number showing on it which will help you to know which one is right for your exact model. The supplier links above are examples only to show the part and what it may cost. Once you have determined which one is needed, search online using the appropriate part number only to get results for suppliers that suit you best.
Here’s the ifixit Asus Chromebook C523N 마더보드 교체 guide that will help you to gain access to the board. In Step.5 the board can be clearly seen and in Step.9 it shows how to disconnect the cables connecting the sub board to the motherboard
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Kayleb Jablonski 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 15
전체 시간: 935
